I ended up with water in the gearcase an I have taken it apart. The leak looks to be from the gearshift rod seal. There is scoring on the driveshaft at the waterpump seal two scores (smooth but grooved) above the woodruff slot. There is no scoring at the driveshaft seal. At what point do I need to use a speedi sleeve? The current seal is intact with no nicks which I will replace since I bought the seal kit. There has been no issues with water flow or overheating.
I need also need to replace the 5/16" gearcase bolts what grade stainless bolts should I use 8-18?
Thanks for the help.
