I wonder why the engine seized?
Struc
Finally got around to pulling the engine out of my "parts boat", which I was told had a seized engine. Thought everyone would get a kick out of this...
In addition to that, there were a couple rods with spun or simply missing bearings (lots of pieces in the oil pan).
Anybody need some spare 4.3l pistons? :D That's about the only salvagable part in the rotating assy.
j_martin
Re: I wonder why the engine seized?
That almost looks like the top secret Mercury Z rod for a 2.5 outboard
Bt Doctur
Water tends to do thing like that.
looks like the 8.1 liter that I got once. engine would only turn 3/4 of a revolution. amazing what power water has
daydreamer1252
Amazing what power the STARTER has.....it seems that most reported here bend when trying to restart....
RogersJetboat454
A buddy of mine still has a bent rod pulled out of a 12 cylinder Caterpillar earth mover, from when he was the maintenance manager at a local quarry. I bet if you melted down that rod, you would probably have enough material make 3 rods for a SBC.
He was saving it to make it into a clock. :)
Struc
I was told the story was that the guy just got done rebuilding the motor, and on the first time out, it started making noises and eventually seized.
Well, I know it wasn't rebuilt, but it did look like the heads had just been off (new head gaskets, fresh (overdone) silicone on a lot of parts). Either way, I'd be pretty frustrated if I just stuck a bunch of money into the engine, only to have it seize on you. I can imagine that's why he sold it off for parts. The guy I bought it from only wanted the heads.
