I don't want to start a debate on generators here, there are a few interesting threads already on here with all the arguments for or against....
I am trying to power my 12500 - 15000 btu AC unit in my cabin cruiser... (I have no on board marine generator).
These are some options, as i see it. I could use a 3000w inverter (is this enough?) to run the AirCon while i am cruising, and use the shore power when docked. and install a 2 pole power switch and use inverter with remote switch, and possibly add a battery or two to run it for a few extra hours.
or I could use an inverter generator to run the AirConC (putting it on the swim platform only when stationary - see other threads for opinions on this!).
My main question is has anyone ever re-wired one of these inverter generators to use it purely as an inverter from the 12v DC battery? and , if so i'd be interested in finding out how it went.
It just seems crazy to buy a 3000w invertor... AND a 3000w Invertor Generator.
It would be great if the manufacturers put a 12 V input on them for just this reason, but i can't find any manufacturer that lets you use it as an inverter when its motor is not running.
Yes, i am too cheap to buy a marine Generator.
Thanks in advance for any advice or input. I'm not too sure how many amps/VA a 12500-15000 btu would typical draw?
Dave
Dave
