Hi all been reading all the past post for weeks. I bought this 1982 20' Trophy about a month ago and have been chasing down this issue. I run 4400 rpm for 30-60min then the engine surges and rpm drop and then it dies even if you bring the throtle down. Try to restart and it will start then die pump the throtle and starts then dies. Let it sit for 45min then start right up runs great sounds great then the prosses repeats.
I've rebuilt the Solex down draft carb and replace fuel pump, plugs, wires, converted to pertronics electronic ignition, replace water fuel seperator timed it to 10deg under a load @ 1000rpm in the water. Temp runs between 185-195. Alternator out put good @ 13-14vdc. water pump rebuilt.
But the last time out with a freind and his son we pulled the spark arester off and check to see if fuel was flowing and noticed that the over flow return tube from the carb had air blowing thru from the fuel pump?
It runs great in the morning then after the first surge and sit prosses it does it all day and your lucky to get it to run for more than 15min in bettween sit times.
Any help in regaurds to this would be greatly appriciated.
