Re: 1956 Johnson sea horse coil information
Ditto that Chinewaler. In addition to making the coils heels flush with the mounting plate, make sure all of the coil and point wires are tucked neatly out of the way to prevent future chaffing. It can be a bit of a pain at first, but you'll get it. One trick I use is to install the coils and tighten down the screws about 3/4 of the way, then you can squeeze or pinch the coils in towards the center of the magneto plate with one hand while tightening down the coils screws with the other hand. To check if the coils are properly aligned, remove the spark plugs and replace the flywheel (no need to put the nut back ye). Now rotate the flywheel (CLOCKWISE) a few times by hand. If you feel any rubbing, then you'll have to realign the coils again. If you don't feel them rub, test the quality of the spark in the same manner by rotating the flywheel CW. If you have good spark and no rubbing, you're probably ok to replace the flywheel nut and tighten it down. Good luck. Keep us posted.
p.s.
I've got a great pic of how to align the coils, but I can't find it :/ I'll post it when/if I do.
