My son and I are trying to get my Grand Father's 9.5 Johnson MQ 12A running. We cleaned and rebuilt the carb including Welsh plugs, lots of junk in the bowl. New fuel pump and lines (pumps well). New spark plugs .030, points set to .020, and good spark with tester at 1/4'' plus. compression on both cylinders 80psi.
We set the low speed needle out 1.5 turns, choked and got a sputter. Subsequent starts are the same, not much of a difference with choke or no choke. It acts like the engine is not getting fuel after the initial sputter. Plugs seem to be dry. Every once in a while fuel squirts out of the overflow vent after a sputter (float was set level with carb body).
Any suggestions would be greatly appreciated.
Thanks in advance,
Trevor
Thanks in advance,
Trevor
