Re: Can throttle controls keep a 1999 Mercury 200 EFI from starting
If the charging system failed and you have been running the battery low you will have a problem. Actually, two problems.
One, the EFI requires a minimum voltage to function, a low battery will crank the motor but the fuel system will not function.
Two, a slow cranking speed will not generate enough voltage to fire the ignition system.
So the first thing to check on an EFI motor is battery voltage, key OFF, then again while cranking, as a marginal battery will drop voltage while under load.
You want to see 12.5 volts both at rest and no less than 11.5 while cranking, if voltage begins dropping under 11 you may begin to have problems with the EFI. Charge the battery fully and retest starting.
Once the motor is running, advance the throttle to 1800 to 2000 and recheck battery voltage to see if it has increased. If no increase begin testing the rectifier.
