Blocked Cooling System
chrisgray1985
Hello everyone,
Right now I am only getting sputters of water and steam from my "pee hole" and the occasional random steady stream for a second or two. I have a 1985 7.5hp mercury 2 stroke without a thermostat. Since I purchased the engine I always had a steady stream of pressure. Then one day it stopped, upon inspection I found my impeller to be completely torn up and all fins were gone. I replaced the impeller properly and tested it separately with a drill and it pumps out firm pressure with no leaks etc. my "pee hole" and hose/fitting going into the engine are clean. I can place a hose or compressed air into my flush and it will come out the "pee hole" strong, but if i place a hose or air line to my cooling pipe that connects to the lower unit I only get weak pressure out of the pee hole. and if I blow the opposite way i get weak pressure out of the cooling pipe. When I do this I also hear air escaping from higher up in the housing where the cooling pipe is. Water also flows strongly out of here, but weak through the pipe. I have flushed and run CLR through to make sure it was not dirt (engine has never seen salt water, and this happened once the impeller blew). I suspect that A chunk of impeller found its way up the tube... I have searched everywhere for advise, has this never happened to anyone!!?? lol. I am desperate. I am about to pull the engine off to take a look, but I am not exactly an expert mechanic and would like to hear some opinions first.... If this is what I have to do can someone provide some pointers. I really appreciate any help/theories/suggestions.
THANKS!
James R
Re: Blocked Cooling System
Almost certain that pieces of the old impeller are stuck in the bottom cavity of the power head.
Only one thing to do now, take the power head off and clear the blockage.
