Does anyone have a suggestion on how to remove the poppet valve (#15) on a 1993 40hp tilt?
It looks like it might thread in, but I think it is pressed in lightly. I've spun it with a screwdriver, but it doesn't back out, only spins. The reservoir filter and valve seat were also lightly pressed in, but they pressed out easily.
Is the trick to use a small pin to push out the shuttle spool (#14) and poppet valve through the stern side poppet valve seat's hole?
I've ordered a new o-ring set, so I was thinking I would need to replace the o-rings on the on the valve seats.
