Hello everyone. I'm looking to mount my transom mount transducer in-hull, in the engine compartment. I have a Maxum 1800MX bowrider. My fishfinder/chart plotter is a Lowrance Elite 5 Gold. I've been researching this quite abit but haven't put it all together yet.
I'm thinking of using 3 or 4" plastic pipe, cut on the hull end to match the hull angle so the pipe will sit vertical. I assume I want the transducer to sit vertical? It seems mounting the TD directly to the hull with epoxy or silicone it is recommended to mount it to match the angle of the hull.
The other end will be threaded to be able to screw on a cap to keep the mineral oil or whatever I use inside and prevent leaks. A hole in the lid for the cable to pass through will have to be 3/4" which is the diameter of the display unit end. The cable is permantly mounted on the TD end. Unless I can cut a slot in the pipe to have the cable pass through the side wall rather than the lid. Sealed with silicone?
I plan on taking a buddy to find a good mount location that gives good signal at rest as well as at speed.
How is the TD held in position? It must be anchored somehow? None of the posts I've read discuss this.
Is the TD mounted touching the hull or is it kept suspended in the oil?
I understand some signal loss will occur due to the fiberglass hull. What about the fish finder capabilities? This has not been mentioned in any posts I've read. The unit is rated for 1000' so I'm not concerned about losing the ability to read the bottom. As I'm going to be salmon fishing I am concerned with the ability to pick up fish or not. Anyone shed some light on this area?
Thanks in advance,
Ken
Thanks in advance,
Ken
