New to this forum.....appreciate your patience with me...1992 40 HP Evinrude Model VE40ELENJ...was running fine, but last season replaced power pack(not coil) due to failure to start; First time out yesterday(bad year for fishin and boating)....stalling when pull back on throttle and/or stopping; Once started again, and put in gear....dies .... removed carbs and cleaned; now starting is easier but still won't hold idle without pushing in choke for awhile; sooo, push up throttle lever to start...worked better but as soon as I bring it to neutral, will die again.....after a few tries at this, started with throttle lever at halfway and it starts; BUT, takes off automatically and can not shut off motor with key and/or ignition kill lanyard; (THIS HAS NEVER HAPPENED BEFORE!! However, when running at high rpm's, the motor sounded better than ever....clearly an electrical issue with not shutting down, but could this be causing the bad idling? Is it under the flywheel with stator, etc? Could something be loose? Any suggestions to try would be great! Your expertise is appreciated too!
