1958 Johnson Seahorse 10 QD-19 Dies after 20sec of idle on its own, it sounds like one cylinder is missing. I can keep it running by pushing on the throttle link on the carb but no matter how fast or slow i make it it still sounds like its missing.
I checked the points and they are within spec .020", and all the coils and condensers look oddly shiny and new. Plugs and wires look good. The gas tank pumps up fine with good resistance and no leaks that I can see, but one thing that did catch my eye was watching the float bowl fill all the way with every pump of the gas tank but slowly dropping back down to the bottom after I feel maximum resistance from the pump. Theres no measurement line on the clear float bowl cover so I have no idea if this is normal or not.
Could this be low compression in just one cylinder or could it be a bad condenser problem. Any info would be greatly appreciated, Thanks!
