Hi guys,
I have a 99 251 proline a real heavy boat with all of my fishing gear auxilary trolling motor, fuel etc. Around 9000 lbs fully loaded had it weighed last year.
I have been experiencing major power loss over the past few years. This boat new was 4400 to 4600 RPM. It has a TBI 250HP Bravo III.
Now it feels like the boat is really laggy and slow, I am lucky to get 4000 RPM, sometimes I cant even get 3400 RPM if its loaded, then I change the fuel filter and I get some power back, usually up to the 4000 RPM. But never back to the original 4400 - 4600 RPM
This boat has always been run nearly full throttle to the fishing grounds and back and has approximately 670 hrs on the engine. The engine runs smooth starts smooth seems to run great but no power it seems.
I have tried different fuel additives even change the fuel filter and check for moisture but still cant find anything.
So 2 Questions
1) Is this a fuel problem or injector problem or some other problem? What should I check?
2) If i need a repower a)can I upgrade my longblock to a 6.2 and reprogram the MEFI chip? b) can i replace with a 5.7 block and change the injectors and reprogram to get 330 HP?
for the repower questions what must i do to make either work properly, I think this boat needs more than 250 HP and more torque, the 6.2 may be the way to go.
Thanks in advance for your help and advice
So 2 Questions
