Re: Trailer Tire Wear
A toe issue will cause wear on one side of the tire. One a single axle trailer is the toe is out the trailer may dogtrack. Toe in will eat the outside edge of the tire and feather the inside. Toe out will cause the reverse. However, the tread will take on a sawtooth-like appearance as the rubber will be getting "scrubbed: from the carcass. Cupping is a classic balance issue. It can also be an out-of-round issue but the balance issue is much more prevalent.
78- if you are feeling a vibration from the trailer through the hitch and through your vehicle all the way into your butt, you have a serious issue. Either the tires are out-of-round ( and balancing won't help that) or you have a trailer integrity issue. Vibrations can accelerate wear on the trailer and on the boat. I've seen consoles, handrails, bow rails come loose, accessories like radios and depth finders die early deaths and wear on hulls where guides or straps contact the gelcoat as a result. Vibrations are not to be taken lightly. They will destroy your stuff.
