GettinBetter
- Aug 15, 2010
- 15
Hi people,
I have the above model engine which is miss-firing. Checked all compressions, and although I am not sure of the cylinder order, they range from 105 to 112 psi. The symptoms are that it seems as though a cylinder is firing early and backfires, and slows the rpm right down, at about 2000rpm it remains running, but at slow rpm it comes to a stop.
I have removed one lead at a time to see if I can pinpoint the area, but it doesn't make any difference, because the backfire persists. I would like to confirm the firing order is correct, as the wiring has been disturbed at some point, but have no manual.
I have just identified the engine and year via these forums, and will order a manual asap.
In the mean time, could somebody possibly tell me which color wire goes to which coil, and identify the cylinder numbers (logically I would have thought that the port side going down would be 1,3,5, & the star' side 2,4,6).
Many thanks
Regards
Les
Many thanks
Regards
Les
