vr02 system
tilyukon
i have a 95 johnson 130, when i get the boat out of storage, i have found that i have to drain the carbs of oil, in order to start the engine, is there maybe something wrong with the fuel/oil pump assebly, or is this normal for stoarage.
thanks
Chris1956
Re: vr02 system
Well. if you left the carbs full of fuel, the gasoline would have evaporated leaving the oil behind....
boobie
Re: vr02 system
Check the cap on your remote oil tank to make sure it's vented. When the boat sits the oil tank can build up pressure causing your prob.
