cavitation plate hole
rstam88
I have a 1958 Johnson 7.5 hp AD-12. I noticed a very small hole in the underside of the cavitation plate from which lower drive oil seeps if I tilt the motor while carrying it. Is this normal, some kind of overflow?
nwcove
Re: cavitation plate hole
you sure its gear oil? ...not just unburnt oil from the exhaust sys? if gear oil runs out.....water gets in.
rstam88
Thanks for your reply. My second choice was un-spent 2 cycle oil from the exhaust. I'm not sure of the purpose of that hole. It is very small and I've never noticed it before. Could be oil from the exhaust.
