  #1
Old June 28th, 2005, 05:47 PM
Rculmone Rculmone is offline
Default Mercury Thunder bolt ignition sensor problem
I have 1999 Mercury engine it has the thunderbolt ignition the sensor in the distributor continually fails. I have replaced it five times. Each time the engine works fine for 2-3 hours then the sensor fails. Any ideas what is causing the sensor to fail.Its a merc 310 electronic ignition rculmone@aol.com
  #2
Old June 28th, 2005, 06:23 PM
FreeBeeTony's Avatar
FreeBeeTony FreeBeeTony is offline
Default Re: Mercury Thunder bolt ignition sensor problem
what do you mean it fails.........can you be more specific?
__________________
'84 Grady White Offshore
350 Mag w/ Vortec Heads
Alpha 1 Drive
  #3
Old June 28th, 2005, 06:26 PM
Don S's Avatar
Don S Don S is offline
Did you check the bushings in the distributor? If they are worn out and the distributor shaft moves a lot, it can hit and destroy the sensor.
__________________
Don S.
Why is there never enough time to do it right the first time,
But always enough time to do it again?
Please, NO PM's (Private Messages) regarding boat/engine problems.
That is what these forums are for.
Only forum/moderator issues will be answered in PM's.
  #4
Old June 30th, 2005, 10:11 PM
Thanks for the help folksI have resolved the problem.the v6 and V8 thunderbolt ignition systems have a service bulletin that discribes this problem. Apparently there is a ground fault in the ignition system. and if the sensor in the distributor is not grounded it will fail (cease to funtion) causing the engine to stall. There is a revised ignition sensor with a third wire (black) which is intended to be connected to ground. I installed the new revised sensor and the problem has dissapeard.Again thanks for the helpRichard
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1969 Mercury 100 H.P. Thunder bolt lower unit downingd Mercury & Mariner Outboards 1 May 4th, 2006 07:24 PM
super thunder bolt katbird Mercury & Mariner Outboards 3 October 6th, 2003 02:59 PM
Ignition problem 92 mercury 115 hp deerejohn Mercury & Mariner Outboards 0 August 3rd, 2003 06:32 AM
9.8 Mercury ignition problem kinfine50 Mercury & Mariner Outboards 4 July 4th, 2003 03:42 AM
thunder bolt ignition system ez4u Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 August 17th, 2002 07:02 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
