Hello,
First boat, so I'm learning
my boat has a merc cruiser 140 w/ alpha one outdrive. When I run the boat w/ the muffs, on the trailer, volts read right on. Over 13 while running and 12 when motor not running w/ key on. Put the boat in the water, voltage gage malfunctions, drops to nothing, occasionally will rise between 9 and 11, never up to 12. Any ideas? Also I noticed the electrical wires going into the trim stop things(sorry, not sure of tech term) on the side of the outdrive, have about an inch of the wire insulation missing and bare wire exposed. They are in same shape on both sides of outdrive. Could this b my problem? Any advice/help would b greatly appreciated. Thank you.
Ken.
Ken.
