gonecommission
- Aug 21, 2011
- 6
First year with a used 27 Cabrio. Trying to understand the DC wiring. Just below my floor
is an 8" x 8" covered utility type box that houses a float switch that I believe should control a small pump to eject the shower water. Looks like it has not run in years. I removed and cleaned both and they work in my garage. I do not detect any electrical current to the float switch. I wonder if a fuse or breaker may be faulty.
Is there a panel box? I see a few push bottons here and there but no where that I can check and replace or reset a breaker.
