l008com
- Jun 14, 2007
- 730
My boat has developed an odd behavior. It lists sharply to the left when I plane out. Which is weird because I would have thought that uneven weight would have caused the boat to tip more when you're going slow. And once you plane out, shouldn't the lean tend to go away, or at least diminish? So maybe the issue isn't weight distribution, but a problem with my trim tab?
Before I go any further, my boat is a small 15' fiberglass bowrider with a 90hp mercury.
And I'm not 100% sure that the little fin behind the engine is called a trim tab, but whatever it's called, could that be the problem? How do you properly calibrate them?
I can tell you that there are no problems with the hull, no abnormalities at all. The only new thing is a depth finder transducer hanging off the back of the boat. But it's very small, I can't imagine something that small could be tilting my whole boat as much as this boat tilts when I give it gas.
I'll try to take some pictures and/or video of this thing in action next time I go out, maybe something will look out of order to you guys?
Back in this boat's previous life, we used to pack it up with passengers and cruise around the lake all day long. Passenger weight was regularly off balance, but it never cause more than a slight lean.
