beechhouse
- Mar 19, 2011
- 14
Has anyone replaced a merc trim limit or position switch with a Sierra 18-7633 Trim Sender. Mine are the old style with screws on the stitch (non sealed). I want to replace the switches without tearing the bell housing off the boat, has anyone just replaced the switches and if so does this sierra kit allow you to do this without having to run the wires through the bell housing.
It's an old boat and I don't want to tear it apart. The issue I am having is that the engine will only trim up with the trailer switch, trims down fine with the throttle switch but only up with the trailer switch.
All the fuses and wires look OK so I am assuming it is the limit switch.
Any advice?
Any advice?
