Firsttimer1
- Aug 20, 2011
- 6
I have done some basic test to this motor compression is 125-130psi but at 1/4 throttle or less under load it is missing. Just had my muffs on it and running it i can unplug the bottom 2 cylinder plug wires and hear it has good spark but doesnt affect the way the motor is running... Had the carbs apart and cleaned them and didnt seething wrong in side of them other then the 2 top carbs had idle mixture screws in carbs and the bottom 2 just had plugs in them. Just bought boat so not sure how long problem has been going on but has been getting harder to start up the last couple of times out on the lake. doesnt want to idle unles you give it a little gas or hit the choke putton on igntion. Anybody have any ideas on where a guy should start?? Been a mechanic for about 15yrs on cars but these outboard are a little differant but can work my way around them if i am pointed in the right direction. Thanks in adive to any advice
