Re: Honda bf8 dies
Sounds like your BF8 is dying from fuel starvation for the motor to initially run well, yet consistently die after about 30 minutes. You may be may be pulling a vacuum in your fuel system.
Are you using a portable fuel tank? Is the gas tank vent in your gas cap open? Is it not clogged? Is your fuel line primer bulb collapsing?
If you're drawing fuel from a built-in tank, try a portable tank (with vent open). If the problem goes away, see if the check valve of the built-in tank is clogged/sticky.
Good luck.
