Re: Overheat 4.3 with omc king cobra outdrive
Its a 1989 4.3L V6 model(well doesnt seem like a model number) 262aprmed. King Cobra outdrive. And actually getting some water at idle to thermostat with more at a little higher rpm. So maybe a week pump/impeller?? But heres the kicker, was going to take the boat out, only had to idle it over a short distance and noticed some water coming out of hose to thermostat, so I put hose back on, increased power, and temp came right down to 130, runs cooler at high speed, at idle temp increases maybe 10 degrees. So: now maybe thinking I had a stuck thermostat or a clogged intake(although i checked that didnt seem clogged) and maybe a week stern pump also. although I usually dont think of having 2 problems at the same time. But bottom line is right now all is good. But going to order a new thermostat and maybe a pump kit. Any other thoughts I would appreciate. Also I didnt say in orig that It 1st overheated just idling across lake was 225 degrees when i first noticed it.
