Augoose
- Mar 21, 2010
- 1,220
All,
this is a '89 Alpha I gen 1 Mercruiser lower unit. I had suspicions as to what was acceptable as far as metal shavings collecting on the drain screw so I drained some gear lube as part of a mid season inspection. When I removed the screws, the bottom screw had quite a bit of what I can only describe as metal paste collecting on it. When I rubbed it between my fingers, it had a texture like graphite lube - no chunks, no hard material, it was really like a metallic paste.
The upper screw had some as well, but not as much as the lower. Attached is a picture of the paste collected on the upper screw. I had already cleaned off the lower by the time it occurred to me to take a photo.
Can you all give me some guidance as to whether this is acceptable or indicative or a larger issue? The boat runs great, no chunks of metal in the gear lube that I drained and no sign of water in the lube.
Thanks!
Thanks!
