I have a problem with one of my 200 HPDI motors. The motor only runs on 4 cylinders both in neutral and in gear.
The obvious thing is the neutral safety switch, but it is working correctly, or least as far as YDS is concerned. It shows ON when in neutral and OFF when in gear. Cylinders 2 and 3 show as off in neutral and in gear, and it is definitely only running on 4 cylinders.
Any ideas on what this could be or where I should look?
I understand that there is a second switch, a shift interrupt switch, but don't know where it is? Where is this located and how do I test it?
Thanks
Thanks
