Quick recap, I have a 81 mercury 150 black max. It starts and idles fine, but if you put it in the water, and try to take off it bogs down, if you keep playing with the throttle and the trim it will finnally take off and runs perfect untill you slow back down then you do it all over again. But the last time I took it out twice out of about twelve times it took off like it should and ran great. Now whats been done to it, took it to a mech in the spring to have the carbs cleaned and redone he said that was my problem it wasnt called him back he said it was the stator I replaced it it wasnt the problem, took it back to him 100 miles, this time he said it was the prop so I bought a new prop, wasnt the problem called him back and asked if he did a link and sink when he redid the carbs he didnt. So I still thought it was still a fuel issue I bought differant carbs and put on it but it still does the same thing. Good compression good spark, new plugs new fuel lines, the guy that owned it before put all new electronics on it. Any ideas would be greatly appreaciated thanks guys.
