When I squeeze my ball, should fuel be coming out the throat of the carb?
Huntleybill
1972 Evinrude 40 HP.
Motor is not running at the time. If the answere is no, can you elaborate on what might be wrong and the fix?
If it is normal, please let me know.
Thank you
Daviet
Re: When I squeeze my ball, should fuel be coming out the throat of the carb?
No, it sounds like the needle/seat is not shutting of the fuel. You will need to remove the carb and check it out.
ONERCBOATER
is the engine level when this happens or tilted?
Sean
Huntleybill
Sean
It is on a stand so it actually leans forward a little bit. It is not perfectly level.
rtgambit
I'll second this. Something isn't quite right with the float, so it's not stopping extra fuel from entering the bowl from the pump line.
cajuncook1
Fuel is accumulated in the bottom portion of the carburetor known as the carburetor bowl. When the fuel level in the bowl starts to fill up, there is a float in the carburetor that pushes a fuel pin(float needle) up and prevent fuel choking or flooding out the motor. If that float needle is worn or coated with junk then it can not seat or seal properly so the gas over flows or leaks out.
Also the float, if it is the original, could be damaged from ethanol(shellac is removed), water logged so to speak with fuel and does not provide the floatation needed to lift the float needle up to seal off from more gas entering and flooding out the motor or cause leaking.
So, long story short, Daviet is right when he states that you need to investigate your carburetor and get a new carburetor kit with a new modern ethanol resistant float.
Here is a picture of a carburetor float, float needle and hair pin. The portion of the carburetor is up side down to evaluate the level of the float and hinge. But normally that portion of the carburetor is the flip around with the float sitting in the carburetor bowl and as the fuel fills the bowl then the float lifts up and causes the float needle to seal and seal off more fuel from choking out the motor during idle or leaking when not being consumed at wot.
Mas
I don't know...but your thread title doesn't sound good!
Mas
BonairII
Mas
I agree. I thought it was some kind of porn using marine terms for body parts :eek: :D
Huntleybill
Mas
I know. My wife called me a sick @#$%!! I keep telling her I didn't make up these part names!!
Mas
I prefer to call it a "bulb," to avoid any confusion and snickers from the peanut gallery...which I guess I am part of!
mas
1946Zephyr
Yea, I have the same issue with my old 35 and what I would like to know is where I can get one of the newer plastic floats. I even re-kitted my carb and it still does it. Oddly enough, the new OEM kits are still coming with the old style cork floats. Sorry if I seem to be highjacking this thread, but this is an odd problem that I would like to resolve too.
aerobat
Master Chief Petty Officer
i had also to LOL reading this... well... it may be that you give a shot of fuel out the thraot when you squeeze you ball... :facepalm:
