I have a 2002 6hp-4str outbd on a 23 ft sailboat. been satisfied with the engine except for the following:
Finicky low-speed carborator fouling....so far have used a fuel stabilizer and also Techron(at about twice the suggested conc) in the gas tank and along with running the engine dry after every use seems to address this problem.
Engine vibration...especially at low rpm...this engine does vibrate alot, it seems a common problem for 1 cyl 4 str engines.
I was thinking of using some kind of vibration-dampning pad/material at the attachment of engine to boat to try and cut down this annoying and possibly damaging vibration.
Does anyone know of any vibration pads/material that might be suitable for this?
Thanks for you help.
