Speakrdude
Ensign
- Feb 25, 2004
- 942
I hope this is the proper spot for an AC question.
If not, someone point me in the right direction,
Here's my issue. The PO has installed, (year unknown) a Mermaid 6500btu AC unit with reverse heat. When I turn it on, the compressor comes on, the fan is blowing. The low side (I think) tubing is getting hot, The compressor is getting hot, no cold tubes anywhere. Eventuallly the comprssor will kick off due to thermal overload.
If I turn it to heat, It hums real loud and pops the main (shore power) ac breaker.
This sounds like a reverse solenoid problem, however, I have read that the solenoid is normally in the cold position not the heat. So it would make sense if the unit was stuck on cool and not Heat.
All the obvious items are working properly. Water, filter, fan, etc.
