Need to remove carb on 1969 6hp johnson. Appears I have to remove pull starter to get at 2nd nut? (bummer) . Is this correct ? Any tricks on removal of pull starter in regards to spring tension so I'm not left with a mess. thanks
This is why it is always suggested that your first step should be to buy a Manual. (I got my 6HP OEM manual for $20- on eBay, delivered. I'd pay $100- now, in a heartbeat).
There is a lot of trouble waiting for you if you mess with that starter without knowing what you are doing...and the manual will help you avoid most if not all of it.
