Hello all...I got some questions regarding the VRO pump. I have a 96 115hp V4 Johnson. If the oil side of pump fails, does the fuel portion side stops pumping fuel as well?
Also, for these VRO engines, does the carb get two separate oil and fuel lines going into them, or there's one line filled with both gas and oil going into each carb? I noticed one of my carb inlet lines got ruptured, leading to some scoring on that cylinder recently. Not sure if carb wasn't getting enough oil or both the oil/gas. Currently deciding if I should leave the VRO intact and just replace the carb lines.
Please advise...
Please advise...
