I have read in other posts that the ball gears should be replaced as a set.
On my 1979 800, I am replacing the upper with a unit that is assembled and has a new ball gear.
I wasn't going to work on the intermediate and its current ball gear. I would say that the amount of wear is approximately 15%. The ball gear on the imtermediate is in good shape. The ball gear on the upper unit side that is getting replaced was worn about 40 percent.
Is it required to replace both gears? I don't see it mentioned that it's required in the manual.
What are the risks if I don't replace the ball gear on the intermediate side?
Thanks,
FT
Thanks,
FT
