Re: 5.0l GXI Volvo Wont rev over 3000rpm until plaining
Actually, you can buy just the HP pump, its about 250 bucks. Adapting another one, it's kind of a funky setup, would take some doing. I think the USCG _)states that it has to be mounted on the engine (I could be wrong about that) so that kind of limits what you can do. I think they would last longer if they were mounted away from the heat and vibration. But just replacing the HP pump you have to ask why it failed. Is it because the LP pump isn't working right, are you getting air in the lines, is the cooling passage clogged? The tests need to be done to properly diagnose the issue, whether or not they stay with the factory pump or use something else. If you could come up with a suitable solution you would be a hero to a lot of people....Prior to 2000 they had a setup where the two pumps were in seperate locations, and both were replaceable, wish they had stuck with that setup.
