Heats above 3.300 RPM Volvo Penta 3.0GLP-D
armandoe
A Volvo Penta 3.0GLP-D heats to 100 ?C when it runs above 3.300 rpm.
It is Ok under it but it heats afterwardsif a rev down the temp drops to 80 - 90 ? C.
I had a broken impeller that I changed and it pumps water OK the exhaust manifold is not hot I dont know if bits and pieces of the old impeller are inside or the thermostat is wrong.
The serial number is
3869304
4012178961
Don S
Re: Heats above 3.300 RPM Volvo Penta 3.0GLP-D
Time to pull the thermostat housing and check it out. May even be a faulty tstat.
Put it in some hot water and see what temp it opens at.
