Re: Temperature rising at idle
Which engine do you have?
I had a slow speed over heat years ago, and it was related to the highly corroded T-stat housing, that didn't allow the little white plastic "check balls" to properly seat. But that was on my raw water cooled 1990 5.7.
The check balls provide some back pressure, which keeps the coolant circuit topped-off, as well as helps to equalize the water that's divided to each of the exhaust elbows.
If they don't seat well, cold water from drive can exit to the elbows, bypassing the block.
