Melted piston!!!
bloopbloob
1975 75hp Johnson, thought I had a blown head gasket or warped head... Took it apart, and found a heavily damaged middle piston, and the head is the same. Very deep pitting in both. The cylinder wall is not scored, and fairly smooth, only a little bit rough, but I believe that its just very minor surface rust from all the water getting in there.
Compression test in top and bottom pistons was the same, 138psi (cold). So now what do I do? Is it worth fixing? Can it be done by someone with limited experience? Or is this something that needs to go to a shop, or is it just not worth fixing? I have almost zero knowledge of 2 stroke motors, but they seem much simpler than a car engine, which I am fairly comfortable with fixing most things on. How much time and $ would this cost to repair?
Thanks for any advice, much appreciated!
Haffiman
Re: Melted piston!!!
Fixable? - Yes!
Price? - depend.
You will need an OEM workshop manual, no Seloc or similar!
You will need some 'special' tools like flywheel puller, torque wrenches and perhaps a hoist to get the powerhead/engine off. The rest is standard wrenches and sockets.
You will need at least one piston with rings and 2 ring sets for the other. A complete engine gasket kit and not to forget a new head. The one on the pics is not to be used again under any circumstances or you will be back to square one very shortly.
If you can do it, you have to decide, but it is not rocket science!
PS: Keep it off that shade tree mechanic that said it was just a warped head!!
emdsapmgr
Looks like part of the top ring let go. Before you jump into a rebuild, you should try to determine just what went wrong-first. Would be interesting to do an autopsy on the middle carb. Any chance that there is some dirt or debris inside the high speed jet that would restrict fuel flow to that cyl-causing it to run lean?
Haffiman
bloopbloob
Next problem! I can't seem to find the parts I'd need, on this site, or on the evinrude site either (says not available). Does that mean I'm SOL? Or can anyone tell me where to find a piston and cylinder head, and anything else I might need?
I'll add that a used 75-90hp motor (1980's) still goes for about $4000 from what I've found around here....
As for the mechanic, there are only 4 Evinrude/Johnson dealers in all of Alberta,Canada, (where I'm at) that I've found, and this guy is the only local option...
All help/advice is appreciated. I'm losing hope!
Haffiman
archcycle
I did some quick googling and the .020 over piston sets are easy to come by for $90.
.030 no, but i didn't look too hard.
Find yourself a good looking head on ebay.
Haffiman
Watch out for piston quality on this engine. There are some low quality low-pressure castings out there at 'rip-off' prices. (WISECO I have used and knows that work, so does original).
They often ends up after a short times as:
R I P !!!
TN-25
I notice that your motor is a 1975 Johnson 75. Both Johnson & Evinrude offered a factory optional high-compression head for those very engines but dropped it soon after from non race engines. Perhaps you have a high-compression head and as such means the engine has higher octane fuel requirements. Sustained detonation from inadequate octane can crack pistons & break the ring lands. Just a thought.
retiredfornow
All those "dings" are from ring pieces bouncing around in there. Stock standard pistons are out there, just takes some looking. I would hone that cylinder, then mic it, to see if you can get away with the stock piston before you order any. You may have to bore it out.
http://www.americanoutboard.com/ may have a used head. Start on ebay, that's where I found my head and piston. Good luck.
Forgot to mention, the hardest part of that job is cleaning the gasket surfaces, honest.
Faztbullet
That head aint that bad, a machine shop can shave it about .020 and any remaining dings will fill in with carbon. Just make sure there are no ring pieces embedded to cause a "hot" spot. As to pistons I'll take a cast over a forged anyday. On that engine it has the "small" rods and most aftermarket piston need a rod kit to make work. (wrist pin size is different) I myself sell customers later model rods when I rebuild them as the rod kit needles are very small in diameter. Also thats a "stinger" block and could have the high compression head as posted earlier,below is my block I have for sale....
http://nashville.craigslist.org/boa/2672769366.html
