water in bottom cylinder of 40 hp mercury
n1xmm
Hi, I have a Mercury 40 hp Classic 4 cylinder Oil Injected outboard serial no: OD229057 Brunswick Corp. Fon Du LAC, Wis. USA. It is a 1993. The trouble I am having is a small amount of water is entering the bottom cylinder. After a short time of running the motor the bottom spark plug stops firing due to water shorting it out. The motor has never been in salt water so I ruled out corrosion through the cylinder wall. The engine looks like new, the paint is not discolored so I ruled out over heating. All the cylinders have 125 psi. It came off a pontoon boat. What else could be the problem? Please help save my families camping trip this summer by giving me a hint of what to look for God Bless!
chum1
Re: water in bottom cylinder of 40 hp mercury
Lower crank seals or water exhaust cover God Bless!.....should be ready by summer 2012
n1xmm
Thanks Chum1! You are a very helpful God Send! :) Will replace suggested parts and post my results!
Sea Rider
Also check head gasket condition, place a new one if found defective, torque to factory specs.
Happy Boating
