Long time reader first time poster.
I have a 1976 Chris Craft Lancer I am restoring to its previous glory. I inherited the boat from my father in law who was the original owner. The problem I am having is that it starts to mis-fire at higher RPMS (>2K RPM). It starts and idles great but starts to mis-fire past about 1/4 to 1/2 throttle. To date I have 1) rebuilt the carburetor 2) replaced points, condenser, plugs, plug wires (set dwell and timing aslo) 3) replaced fuel pump and filter/separator 4) replaced gas three times 5) had carb shop check carb- no issues. 5) tested with new coil and external ballast (mine has the resistor wire set up) All to no avail.
I'm at a loss. It's been suggested to replace the points with an electronic ignition set-up. Any thoughts or suggestions are greatly appreciated.
