Cobracompound
- Oct 25, 2010
- 1
I?ve been having a problem with one of my 4.3 Mercruiser engines (4bbl carb). Here are the symptoms:
It starts fine when cold and runs great at idle or until I want to take the boat up on plane. Once I punch it to get up on plane it will rev up fine for about 30 seconds and then bog and almost die. It use to catch itself before it would die and the RPMs would climb back up to 4000 and run fine. Once up on plane it runs fine between 3500-4200 RPM. More likely than not it would only happen once in any given trip. Even if I came off plane and went back up it wouldn't happen again. It has been doing this for a month or so, but the engine would always recover before it would actually stall and then would run fine.
Now, the engine actually dies when it bogs during a WOT run and I can?t get it started again for 20-30 minutes. Then it starts right up like nothing happened.
I?m suspecting a fuel problem which may also be causing the engine to flood (which is why I can?t start it again). But I guess it could be a coil or electrical problem as well?
I'm going to replace the fuel filter, but wondering if it might sound like a bad coil or something electrical.
The engine is a new GM base motor with about 40 hours on it, but the carb and other bolt on parts are from the old engine. It has the thunderbolt ignition and the wires are new. The boat is an 88 Sea Ray Sundancer with twin 4.3l Mercurisers.
Thanks for any advice.
