Re: 19p to 17p how many rpms
I put a Solas alum 19x14.25 4 blade on the boat doesn't plane any better than my 21p 3 blade boat will only hit 4100 rpm do you think a 17 same style would put me in my 4400 to 4800 range what would you try next 17 or maybe lower i want it to tow and ski care les about top speed (2150 Capri 5.0 efi alpha at about 6000ft)
Welcome to iBoats.
Assuming the 21P you replaced was a Mercury alum prop, surprised you did not get any change. I would not expect the same wot RPMs. What was the top speed of each? I am trying the same solas this summer from a 14.25x21x3 Black Max Alum. RPMs did change, but it was even noticable in "seat of the pants", ie quicker acceleration.
I suspect you are fighting a drive ratio issue at that elevation. Do you know the drive ratio? The general rule of thumb, is 300-400 rpm with 2" of pitch. So a 17P solas would give you 4400-4500, and a 15P 4700-4800. The latter would be prefered for skiing.
