Yamaha V4 115hp 2 stroke, model# 115TLRQ, Serial# 392505, Code 6E5L is running very rough. I think the motor is in limp mode because it will start and idle rough but as soon as I try to increse speed the engine will die. Both outboard oil tanks (Large tank on back of boat and small tank on engine) are full but I have a red light activated on my dash that says low oil. How can I test to see if its a bad CDI Unit or test the sensors on the oil tanks to see if they are bad. There is no warning buzzer sounding which usually happens when I am actually low on oil. All I have is the red light on my LCD Marine Meter Yamaha. The red light is above the round circle that shows a low fluid level on it on the far left side of meter. The local back yard mechanic said that I should put a new CDI unit on and see if that works but that is a very expensive part.
Thanks in advance for any help you can offer!
