1978 898 mercruiser idles and shifts but when we take off it will not go past 2200 rpm and then run a little rough then immediately drops down to 1500-1700rpm. We have a 4barrel rebuilt carb on it. Just emptied old fuel and put new spark plugs in it. Runs great in idle. We never have ran this boat in water, so unsure about prop. Running cool temp but when wot, rpm jumps up then back down. (We put new gas in older fuel filter, due to wrong fuel filter was given to us) Also removed check valve by gas tank; we will clean it and replace.
