Re: Water Spray From Transducer
I put a Hummingbird on my boat, If you mount it the way they say to it's to low.
They said to mount the bracket 1/8 above the bottom of the boat. Witch I did
that put the transducer below the bottom of the boat. Everytime I took off I had
more water in the boat then outside. I moved the transducer up till it was even with the
bottom of boat, all is fine now.
Don
