Big_D_in_Mo
- Aug 14, 2011
- 3
This is my first post here, and I'm hoping I can get the correct answers.
I have a 01 Lund 1700 Fisherman with a 02 115 Johnson 2 stroke motor. The prop that came with the boat is a 14x17 3 blade alum. The original prop I'm assuming. This prop at WOT runs 5500 rpm. But, it only runs about 36-37 mph. According to my engine manual, rpm is to be 4500-5500. I bought a Solas Amita 12.75x17 4 blade alum. prop, and it runs 5800 rpm but it will run 39-40 mph. To high of rpm for me. But I like the speed. One prop dealer told me to get a 19 pitch 4 blade and that will drop my rpm about 400 or 5400 rpm and give me more speed. The only 4 blade I've found is a 12.5x19. As you can see I keep getting smaller in diameter. Don't know if this is good or not. So, now I'm looking at, after reading on here, that maybe I should go with a Turning Point Hustler 13.25x17 or 13.25x19 prop. Both are 3 blade alum. Can someone enlighten me on which route to take? One other thing I want to mention. I have 2 deep cycle trolling motor batteries in the front of the boat and a 3 bank charger. A lot of weight. Maybe good, maybe bad, but I am not going to move them. Please help before the wife goes ballistic over me buying enough props to start a business.
My boat is strictly for fishing. No water skiing, no tubing, just fishing. Thanks
