Well I have a 1979 200hp mercury outboard motor. I am getting a little mad at this motor because it is one thing or another, i know thats boating. The now is my starter. I have some what new batteries, about two years old, brand new clean cables that are 4 gauge, brand new stator, brand new plugs, brand new silenoid starter switch, brand new rectifier, and the starter was just rebuilt by a shop. I was on the water fishing and i tried to start the motor to go to a different spot. I tried to start the motor and the starter was turning the motor like the batteries were dead. The starter started off fast and then it slowed down to a crawl. I got the boat out of the water and home to do a little testing. I put the batteries on the charger to make sure they had a full charge. I checked the bateries and both had 12.53 volts before I tried to crank the motor over. The motor cranked over very slow and the meter read 10.46 volts while cranking at the battery. I them moved to the starter realay silenoid and tried to start the motor and the meter started at 12.5 and went all the way down to 8.00, on the volt meter in just 4 seconds. I stopped cranking the motor and the meter went back to 12.5. I took the flywheel cover off and turned the flywheel by hand. I was a little tought buy not to hard to turn. compression is good and not to high/around 112 psi for all 6. I have a couple of questions. even though the starter was rebuilt can it be bad. can i test the starter and how. Why is there that big of a drop in voltage. I even hooked up my brand new truck battey up to the motor and still had the starter cranking slow. Does any one have any sugestion on what to do about the slow cranking of the starter, should i buy an new starter or is there something else going on taht I am over looking. Any help would be nice. Also dont tell me that I need to clean all the connections please because I have done that already.
