jumpjets
- Nov 11, 2010
- 313
I noticed after my last outing that my bilge had a lot of oil in it. I checked the engine oil, and it was full and clean. I pulled the screw out of the bottom of the drive, and about a cup of water drained out!! It was followed by a rather small amount of chunky sludgy super dirty drive oil. It seems to me that the drive has sprung a leak, and all the oil leaked out through the transom coupling area into the bilge.
What part of the drive system would have sprung a leak like that into the bilge?
I pulled the drive and took a peek inside. The rubber driveshaft boot was filled with drive oil.
Other than the driveshaft area, no other areas of the drive mating surface looked dirty or damaged. I don't think the gasket was leaking.
Something else worth noting: THe prop shaft is slightly bent, and it might have contributed to the drive filling with water.
