Engine Coupling/Replacement for 1978 Wellcraft Airslot 260 Merc
mforsyth
I am trying to replace my engine coupling (between flywheel and driveshaft)for my 78' Wllcraft Airslot 260 Merc/350 CID. Any tips or where I can locate parts? Please advise.
jmatteo1
Re: Engine Coupling/Replacement for 1978 Wellcraft Airslot 260 Merc
Mark,<br />I discovered the same problem with my '78 Wellcraft 196 today. i have the 305 V8.(898) Please let me know if you come up with anything, I see that you have gotten no responses so far. Thanks, and good luck to you! Joe
Bt Doctur
any reputable parts store should have it .why did it fail? allignment issue or rear support mounts?these must be corrected first or the new coupler will go bad real quick.<br />drive needs to be removed first. disconnect whats needed to remove/lift-up/slide foward the motor,remove rear mounting housing, replace coupler,reinstall in reverse order,set/adj. engine alignment,install drive.
You Both have a Mod.1,....With a SBC........<br /><br />My NAPA book says You'll be needing an 18-2171........$216.14 List......<br /><br />Pull the Drive,....<br />Pull the Engine,......<br />Replace the Coupler,....<br />Reinstall Everything,......<br /><br />Go Boating.................... ;)
lowshovel1
Item number: 4544797920 new one on ebay-149.99
jmatteo1
I think mine failed because of a problem in the upper housing. The boat sat unused for 2 or 3 years. The previous owner said he had problems getting it in & out of gear. I wasn't getting any water flow, so a rebuilt the water pump in the lower unit, now I found that the upper appears to have seized up. I cannot turn the shaft/u-joints by hand when it's in nuetral. I'm waiting for my #3 manual to come before I start anything. I'm a half a**, back yard mechanic, but I'm willing to give this a shot.<br /> Thanks for your help so far... and in the future. I'll keep you "posted" !!! Joe<br /><br />Bondo... What does the "SBC" stand for? Sorry if that a silly question!
Small<br /> Block<br /> Chevy
jmatteo1
Thanks!
achris
More fish than mountain goat
Originally posted by mark forsyth:<br /> Any tips or where I can locate parts? Please advise.
Yep, back of the engine, which is in the back of the boat. Sorry, couldn't help myself. :D
