sjdwallingford
- May 17, 2010
- 17
Boat stalls at idle and now is sporadic in acceleration and is not reaching top power. Boat was running fine last week. I rebuilt the carbs this spring and the engine has never run better until now . . .
The engine stalls at idle. I changed the spark plugs. Didn?t help. It seemed to me that idle was too slow, so opened up idle screws a bit. No change. In fact, the engine seems unresponsive to adjustments of the low speed jet.
I attempted to avoid the problem by adjusting the idle position of the throttle. This kept the RPMS high enough so I could put engine in gear. Engine sputtered, but cam up to speed.
After a pulling a water skier a few times, engine was having problems coming up to full power. At this time, the engine will not reach full power. I suspect I'm not firing on all cylinders.
I was going to take the carbs off and clean them, however, the fact that the idle screws have no effect on the engines RPM makes me think it's not a fuel issue but an ignition issue. Any comments welcome. Thanks.
